2nd Gen Non-Engine/Transmission horsepower estimate?
Engine/Transmission (1998.5 - 2002) where's the towing power?
Wondering if anyone can give me an estimate of my trucks' power as I can't get to a dyno. I won't run it 0-60 or quarter as I won't take a chance with synchros on this work truck. . I had a '95 I sold with busted 3rd gear synchros I think I got shifting too fast. . Dually 2wd truck is 7300#; 40-80 in 6. 8 secs. . (only one shift)
Oops, looked at signature. . Forgot to put in the Edge Comp. Yeah, without that on the truck is doggy at bottom end compared to stock. . Really gives the boost needle a ride when she hits when it's on 5X5. Has max boost of 45PSI. Pyro tops out at 1200 unless you peg it for a long time. Eventually creeps to 1300. Phat turbo did drop ETemp 1-200 deg. The whistle was fun for a couple days, then I was going nuts. . Got a TAG. Now about like stock. . It also took away some of that nasty bang it made when I shift under load from level 2 on up. . I had a bunch of data comparing the 2 turboes;not sure I can find it though. . You considering a Phat shaft turbo?
yeah I gotta go bigger soon. got WAY more fuel than turbo. with the comp you should be in the 400-450 range
