Wondering about that myself, I conservatively estimated 10% with an auto in lockup, but it might be worse than that, certainly more than that out of lockup. On the dyno, locked up, mine showed 278 HP (& 649 torque) at the roller, at about 31 psi boost. Somewhere in an old TDR back issue, it was estimated each 1 lb. of boost would be roughly 10 hp. If this the case, I'm making 310 HP (At the flywheel?) and putting 278 down to the roller. Believe it or not, this is a stock, original truck with 140,000 miles, and the entry level 230HP/605 Ft. lb. plate moved 1/16" forward. If I estimate correctly, this equates to about an 11. 5% loss through my locked up transmission.
