Horton fan clutch
More Questions for the Experts
More Injector Problems?!?!
hey guys, I read somewhere that the horton electric fan clutch frees up 20 more hp when it is not on. I was just wondering if any of you guys like it or have heard anything about them. Also how much do they cost. It looks intresting and I think it might be worth purchasing... . what do ya'll think?
91 4x4, 5 speed, 3. 54 gears, pw injectors, 12cm turbo housing, K&N air filter, "tweaked" pump, isspro boost and pyro gagues w/A pillar mount, straight piped 3' exhaust
Several of us are running the Horton fan. I had 1 one my hotshot rig i sold and will be buying another one this summer for my other 92 D-350. A great unit. Think ? I paid 650-695. 00 for the last one. I'm sure you'll get more input on this matter soon. Mike
http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, CTD 3500, Air brakes on truck & trailer. 193,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy. 200,000 miles
Just bought another 92 D-350 215 P-Pump motor and NV 4500 180,000 miles 24 lbs boost all stock For now
A few TDR's ago there was a dyno chart and it stated that the stock fan on a 2nd generation used 9 hp. It was the article that explained horsepower needed to pull different weights up different grades.
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft, JRE 3" exhaust, Banks Intercooler, Lucas injectors
I am running a Horton on my '93 and I can count on one hand the numbers of times it has come on in the last year and those are with the A/C on. It has not come on due to heat but in response to high pressure in the A/C system. I picked up 1 mpg with it so it has almost paid for itself.
Happy Trails
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
A couple of Perma-Cool 14" electrics mounted side by side gives you 4000cfm and costs less than $200! Works great for me in South Florida!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N, cleaned-up exhaust with Dynomax straight-thru, rebuilt injector pump, thermostatically controlled twin 14" Permacool electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, Reese Titan 2. 5" receiver, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
