Details here: TDR Privileges
What temp does your Horton fan clutch engage automatically? Does it have its own thermostat? I'm afriad I may have messed it up doing the KDP last fall.
Mine will turn it on @ 200deg. The sender is in the last plug closest to the firewall on top. The instructions that came with the kit said to put it in a plug down by the map sensor. .
The temperature sensor that comes standard with the Horton is set to turn the fan on at 200 degrees. You can replace that with a lower temp sensor if you choose.
