Hose from top of front differential???
Noise around left front wheel
Hydroboost leaking, How hard to change
Driving home from Miami - stopped at a frind's place and we decided to test the new kore suspension - it was great but when we got bact a hose was dragging on the ground
Upon further inspection - it was connected to the top of the differential but I could not find where the other end connected... . Any help would be appreciated
Yes, it is a breather for the diff. in case you get into deep do do, suspend high enough to clear high water but leave enough slack for suspension rebound. bg
Does it still have the little white filter thingy in the end if it? If not you'll want to pick one up at the dealer (only a couple of bucks).
