Engine/Transmission (1998.5 - 2002) Hot Rod VP44 electronic enhancement
Engine/Transmission (1994 - 1998) Lift pump question
My Drag comp bit the dust and since the only thing to do when something breaks is to get something thats... . well..... Faster. SO I ordered a Redline box from blue chip and I'm getting an Edge EZ for timing, I hope this works:-laf. Anyone have any experience with stacking boxes on the HR VP44?
Thanks,
You are... if not already, gonna have a very nasty truck!!! The redline is a totally different animal compared to drag comp. The redline will override the electronics on the truck, should run good... ... ... ... .
I have a HRVP44 had a TST stacked with an Edge Comp, found that the TST works better with the Smarty, that is what I am running now
Rick
I have a TST PM3/Comp stack and it runs awesome, would love to try a Redline to get some more RPM's. I think you'll be happy with the box, let us know how she runs.
Just a quickie is there any way of setiing a say 3500 rpm safety on the redline in case you don't have the springs or the ice in your veins to let it twist any harder, YET or would one have to go with the wizard to keep revs in check OR would the temptation be tooo great to go higher even if rpms coulod be limited????
TST Competition
I have a Smarty stacked with a TST Competition box. I can rev to 4000 rpm with fuel. I am very happy with this combination. Thanks, Sam.
the redline hase a rev limiter from 3400 to 4000 rpm, there is also an unlimited rpm if you ask for it. 0 to 100% fueling capabilities of the pump selonoid. pyro boost and rpm display and a peak values feature.
