Engine/Transmission (1998.5 - 2002) hot rod vp44
Engine/Transmission (1998.5 - 2002) Pump Keyway
2nd Gen Non-Engine/Transmission Vacuum Tank, is there one?
I took my comp out and sent it back to be upgraded to a dragcomp. I disconected everything and with only BAF and 4" exhust the HRVP44 I can hit 32 pounds of boost funny thing is no check engine light ? :D
You're hitting the boost numbers cause of the boost fooler elbow that came with the comp. However, I'm not sure why the "No check engine" light??? Wonder if you put a scan tool on if codes will be there?
