Hotshotsecret(Diesel Extreme) and (Stiction Eliminator)
Antifreeze Test
EZ oil drain plug
It's intended for HEUI type fuel injectors. It's of no use in a Cummins .
The Diesel Extreme, if you go to the site it says it's for all diesel, for cleaning the fuel system. The Stiction Eliminator, is for HEUI type fuel injectors, but its says it clean the turbo system to. The add for this company was on this site.I just want to know if anyone has used this product:confused:
I just ask if anyone has used this stuff, and really did not get a lot of answers, so I bought it to see if it would make a difference. In my case it did make the truck idle a lot smother, and my Exhaust temperature were a little lower. I didn't start this thread to have people get passed off.Just wanted options if it worked for some or not.
No need to explain. Sometimes things get off track. As for additives working, it's tough to get empirical evidence. We often see what we wish for. Of course if you had a sticking injector it may have helped. As long as you're satisfied that's all that really matters.
Guess it's a fluke that my Cummins has 1343000miles and iv never cracked the engine open or replaced an injector or pump right jhenderson?
If it's snake oil I'm happy to use snake oil. Did I mention my CPP built engine pushes 700+ h.p. and I tow 32-36k regularly with my Dodge 3500? This snake oil works!!!!!!
This is quite the accomplishment! Perhaps you can get your legal team to publish some Dyno numbers along with proof your odometer of your 700 hp beast with original injectors and IP rolling past the 1,000,000 mark. Cummins will no doubt be in contact with you as your very likely the first to ever accomplish such an incredible feat. They will most certainly buy your engine back for 10,000 times the face value and put in on display at Cummins headquarters.
We are all eagerly awaiting! :-laf :-laf
Hi guys. I've cleaned up the thread. Non-sponsors here solely to pitch themselves or products (or worse, argue with users) are violating the rules.
My own personal experience with the product, years ago, for stiction problems, is that it did not improve it one bit. If you look up the MSDS, there's nothing here but naptha/mineral spirits. Save your money and if you need an oil or fuel detergent any product based on this will accomplish the same.
Hopefully it won't be long before I get contacted by Dewey, Cheatem, and Howe. The suspense is killing me!
Oh Jeez, now I have to post a few GIF's.......
