I've been told that under 300* is OK. Sounds a little high to me, but I'm no expert. My temp sender is in the top of the left fastcooler, with a filter on the right side. I am experimenting with Amsoil 30w Powershift Trans Fluid and it seems to be working as good as what you guys are running, shifts fine hot or cold. I may try the 50w version next, these are the same oils we use in our big truck trannies.
I have found a 12 volt pump that will work for this, but I'm trying to decide if I tow enough to be worth it. Although a pump and cooler would make it easy to add a spin on filter too.
So 230* is the hottest so far, do I hear 250*?
