Dieselnerd said:On my '05 the hour meter reads on the overhead. Just press the "step" button. If you are in compass/temp mode, first step shows avg. MPG, second step is DTE and since I'm not in the truck right now if I remember right, the third time you press step it shows hours of run time. It is on the overhead for sure though and is also in the owners manual as being in the overhead display.
I guarantee you that the numbers are different. The overhead timer counts up with the ignition on, engine not running (I sat there and watched it). The hour meter displayed on the odometer is actual hours of engine run-time. As discussed, this timer is not resettable, as the overhead timer is.I have never reset mine so it does read my total engine hours to date.
