On my 03 I did the bright box with fog lamp control and moded the fogs to use the 9005's like many have done and while I will agree it is an improvement over stock I was thinking of a different approach for my 05.
Since I vary rarely if ever see fog conditions but regularly drive a night I am thinking of pulling out the fogs and replacing them with a pair of hella120mm modules.
in a high beam configuration and use a 100W Xenon bulb
The lamp lens is very close in size to the factory fog and you probably wouldn't notice they were changed till you turned them on. They are a very deep lamp but there is plenty of room for them. Since they come with that metal frame it should be pretty easy to mount it to the factory fog mounts using metal straps bent to fit.
They come complete with adjusting screws for aiming.
For control I was thinking to wire them like VStahl did his with their own circuit and trip the relay with the OEM high beam feed wire.
Price wise looks like I would spend about 50. 00 more vs a Bright Box/Fog mod, but at today's prices that's only ½ tank of fuel and I bet the light output would be better at least for distance.
Any thoughts on this idea or other ideas??
