Engine/Transmission (1998.5 - 2002) How are these fuel pressures?
2nd Gen Non-Engine/Transmission Cruise control
Engine/Transmission (1998.5 - 2002) F.A.S.S Question
I installed a Westech fuel pressure guage yesterday w/ the new shraeder valve whip. Install was pretty easy on the engine side. A bit time consuming on the interior side but all went well and fit great.
Anyways at idle it reads between 15-16psi. Cruising 70mph unloaded I get 13-14psi. 12 psi under normal acceleration. WOT throttle drops to 10psi and slowly drops until I reached 80 - 90mph then comes right back up when I get off the throttle.
This seems to be in the acceptable/normal range but any feedback would be appreciated.
2001. 5 2500 4X4, auto, 60,000 miles, Edge Comp box w/o tap. Stock lift pump as far as I know. I had the truck since 43,000 and have not touched the pump.
