how can i quiet the mighty PE4200??
Mag-Hytec Front Dif Cover Install
DPP SS exhaust is awesome!!! --Thanks Mark!!
well, it finally happened... the new wife of only 2 months was riding with me the other day in my truck (first time since i installed the PE 4200) and she says "what is that constant whining noise?" don't get me wrong, i like the pump... it looks well built and has great specifications, and seems to work well so far (500 miles) but it is loud. i run mud terrain 33x12. 5 tires and a straight exhaust and you can still hear it over that. i have it mounted on a piece of aluminum bar stock (thanks smokin diesel!) above the cross bar on the frame. this puts it directly under the drivers seat. so with that, how can i quiet it down, mount it on rubber washers? build a shroud for it? or what? any suggestions would be great!
thanks
jeremy
hmmm.......
The PE's I've installed are very quiet. Did you use the isolators included with the pump ? I'd suggest contacting Andy or myself for install tips... ... Rip
