Depends...
What kinda SW is in it? Most likely one for an older than your truck. In other words the engine will not run correctly.
If anything, you could test the ECM in your truck to see if the ECM is operational.
Once in, the WTSL H A S to work correctly. The engine might run very rough the tach might quit working after a few seconds but that's about all that should happen. Everything else in the dash has to work, comprising the Oil pressure. At least you'll know if it works or if it's DOA.
Marco
