My 2006 truck has been in the garage for some months now. (I only use it for towing my travel trailer). I would like to turn the engine over to circulate the oil and spread some oil around, before the engine actually starts. I know that cold starts on a dry engine can produce a lot of wear. Is there a fuse I can pull that will prevent either the injectors from firing or the fuel pump from running.
Any other suggestions for starting an engine after it has been sitting for three months. I have kept the batteries fully charge.
Thanks!
Thanks!
