Pics of both old and new lines here: http://home.earthlink.net/~tlawrence51/How long is the piece that has to be replaced?
No. I put mine in completely dry. It's brass on brass, so I just cranked down on it good and tight, and it sealed up just fine. Remember that it's pretty low pressure going through that line, so it doesn't take much to make a good seal.so teflon paste ok? or what?
Shouldn't be any problem at all. The Mass Diesel line comes with a Tee fitting, middle port plugged, meaning your probe can stick in the entire length of the Tee - approximately 1" long.Is there any problem using the probe that comes with the new Isspro gauge with this cooler line?
