I was wondering what the best way of changing all the oil in my auto is?
I have read about removing one of the transmission cooler lines and letting it pump out. How well does this work(how much oil comes out) and is it bad for the transmission? Common sense says its never good to run a pump dry but maybe it wouldn't hurt for a short time.
I have also heard of loosening the valve body a little to let the oil drain out of the converter. How well does this work and will it work on all auto trans? (I have to change the oil in the wife's GM next)
I do plan on dropping the pan and changing the filter but I want to get as much of the old oil out of the torque converter as possible because it is an used vehicle and who knows if previous owner ever changed the oil. I also plan on running synthetic and want as much of it in there as possible.
