Dial indicator on a push rod is the most accurate way to check. You will need a degree wheel on the crank or damper and set it correctly to get accurate readings.
Your cam should have specs for degrees on intake and exhaust valves for max lift at degrees, and, degrees at . 050 lift for installation purposes.
