Competition How do I find a boost leak?
Competition Truck Pulls in PA / MD
Off Roading Question about off-roading...
My boost is not what it should be. 24. 5 lbs. max on X-Monitor with TST 6/5, BDDL on tow setting, and 80 hp pressure box. Messed with the setting on the TST boost elbow and it's now turned up all the way.
The bottom of the intercooler was bent in an accident awhile ago, so I don't know if it's leaking or what?
Can I pressure test the whole thing in the truck with some soapy water or something?
you have to plug the end of you intercooler with say some pvc pipe, a 2" cap or a 2" fernco will work just have to tighten the clamp down real good. then hook an air compressor to your boost line fitting at the engine side and REGULATE it at 10-20 lbs and spray soapy water at all the joints, it isnt to easy but it will work.
