I've got a new turn signal switch to replace the bad one, but I can't figure out how to get into the column. I'm hoping I can get in there without pulling the wheel. I don't have a service manual. Anyone have some thoughts?
Badunit said:Pulling the wheel is easy with a puller. No big deal. Assuming the clockspring setup is similar to the 2nd gen, have the wheels pointed straight ahead when you do all this so you can make sure the clockspring is centered when you put it back together - you don't want it wound up in one direction or the other.
Jeff Clark said:bighammer, your the man. I appreciate it.
