I have a seal leaking on the shift rod of my auto trans on the 2000 model truck. I thought it may have been the pan gasket, so I changed fluid, filter & gasket. Needed serviced anyway. Nope, still leaks. So I check more carefully & I can see fluid leaking from that seal where the shifter rod/shaft goes through the case to the valve body. Anyone replaced this before? I sure hope I dont have to drop the pan again! May be simple (I hope) Any "how to" advice would be greatly appreciated!
