2nd Gen Non-Engine/Transmission how do i?.......
Engine/Transmission (1994 - 1998) Best setup
lose my cat? i mean, i don't weld. i can turn a wrench. how is this done? i looked at genos. nothing.
any input is appreciated.
thanks.
scott.
what you would be looking for is a muffler elimination kit from genos. which is a piece of pipe bent to replace the muffler.
my suggestion is to spend about 2. 5 times that money and get a complete 4" exhaust:D
Get under your truck with a recipricating saw and cut it out. Then using a straight 4' piece of 3" od with a bell on one end, a 3" id to 4" id adapter and three muffler clamps and you're in business. It takes less than a half an hour to install and will cost you less then $40.
I checked all the exhaust shops and parts stores around here and nobody stocks anything bigger than 3". I'm gonna save the hastle and do as stated above. Save the dough and go with a complete 4" system.
Why not, just replace the entire exhaust system with a 4"? That way it is a bolt up installation and it will fit from the turbo back. You will also gain the performance of the 4" system while keeping the trucks sound very close to that of stock. :)
