10 psi ,
750egt,
2000 rpm
75mph,
150 deg. trans temp (automatic with TST shift kit)
3:54 gears
No wind,
Flat freeway,
57 outside temp,
3 1/2' high shell,
1/2 tank of fuel ,
otherwise empty,
97 2500 Club cab California model.
33x12. 50 tires
Banks Stinger kit?. turbo housing,fuel plate,32 psi boost max,K&N,muffler,
No *****cats under my truck
egr in op.
custom made intake manifold no egr here.
170,000 miles
gets about 14 mpg around town 16 hwy.
Does this sound about right?
What changes should I make next ? (besides the trans. It's next)
Gathering parts for fuel presure gauge set up.
Relay's replaced
Starter contacts fixed.
Need to find a KDP template in So. Cal.
SFB
750egt,
2000 rpm
75mph,
3:54 gears
No wind,
Flat freeway,
57 outside temp,
3 1/2' high shell,
1/2 tank of fuel ,
otherwise empty,
33x12. 50 tires
egr in op.
170,000 miles
Relay's replaced
SFB
