Originally posted by bighammer
Or pull out the fill plug and turn the truck on its side. (like a lawnmower)
Originally posted by sticks
That procedure is for the FORDs. Flip Over Read Directions
Originally posted by Mad Bomber
I forgot to say a real easy way to fill the transmission is remove the shift tower and pour it down. BTW while you have it off you might want to get the B-D short shift kit![]()
I'll play with the single bolt and a squeze bottle, before I play with all 20 of those darn little screws in the shift tower again.
Originally posted by Hpxperts
What weight is the transmission oil for a 2003 6speed (is that a 5600 or 6500?)? Also, have any of you guys installed the B-D short shift kit? And has anybody knowingly bought a used truck from Bighammer or Mad Bommer?
Originally posted by LFarrar
Switched out factory for the MTL( redline ) Madbomber you were right! ( not to doubt you) trany shifts WAYYYYYY smoother. Thanks again Mad
Lou![]()
