How do you clear percentage of mileage usage following oil/fuel filter & oil changes?
3500 leveling
Oxygen sensor code
cooperns1943
We have a 2015 Dodge Ram Diesel Laramie and do our own servicing. How do you clear the percentage of mileage use following servicing?
The owners manual is your friend. For oil life, I believe it's, turn your key to run do not start engine, press accelerator to floor 3 times in 10 seconds turn off key. For fuel filter you use the keys on steering wheel to reset. be sure to confirm reset at the end of that sequence.
If you've got the larger EVIC display that allows you to change screens, you just go to the oil filter life screen and press and hold the directional arrow that is noted in the bottom center of the screen. Then you have to confirm. I can take a picture later if you like (if you have the large EVIC).
