How do you keep the ball joint from spinning?
Road Rage "enhancements"
Where is the VIN stamped
AMink
How do you keep the ball joint from spinning when try to torque it to spec? I did the passenger side and didn't have a problem, but the driver side turns when I wrench on it. Should I use a big bar and crank on the knuckle to try to bind it? Had a weird feeling in the steering, turns out the driver side u joint was dried out and binding. Put in new bj's while it was apart. Thanks!
sometimes a jack handle or prybar works good if you can't get a jack on it, side loading it usually works but it depends on how tough the lock is on the nut
