I used a puller *GENTLY* pulling the hub and pressing against the end of the axle stub shaft. You need to shim the knuckle u-joint against the axle-tube end, snug the puller judiciously and tap the four bolts with a 40 ounce hammer... I used a craftsman 14mm socket as a driving tool between the bolt head and the hammer (SnapOn will not replace one of theirs under warranty if you do this, craftsman will). Anyway, liberal application of your favorite penetrant, judicious use of hammer and careful application of the puller (ensure you are not in danger of warping hub or destroying bearing, unless you are replacing the bearing)
Also, KCanepari, Mr Simonsen is hardly a "newbie", he is quite literally THE FATHER OF THE CUMMINS-POWERED RAM... He and John Keele share the honor of brainstorming the product in the 1980s.
