Spindle nuts
Another good rule of thumb that I have used for meny years is to tighten nut, then back it off till you can move the washer that is behind the nut with a screwdriver. Washer should move with resistance, not too tight and not too loose, kinda like adjusting valves. Then rock wheel back and forth to feel if there is any play in the bearings. If there is very little play or no play and you can line up a cotter key hole, you have got it right on. On some cars like Porsche or VW they used a set screw or double nuts so you could set exactly as it should be. If you have never used this method before, it might take a little while to get the right "feel" as to the tightness, kinda like learning the right way to adjust valves. Have done it this way for over 40 years and no problems. Just another way to do it... for what its worth.
