Engine/Transmission (1998.5 - 2002) How hot dose your 241HD Transfer Case get?
Engine/Transmission (1998.5 - 2002) 241HD Transfer case
Engine/Transmission (1994 - 1998) HX-40 vs Hybred HX-35
How hot dose your 241HD transfer case get?
My at 175 to 200 is this OK? any one else?
This is running empty in 2 wd at 70.
I have 02 HO 6SP :confused:
I have a westach temp sender and quage installed in my 01 HO.
I use Texaco mtx fluid. I have had the qauge set up on my truck since 5,000 miles. I now have 35,400 mi. I have kept a log on temperature on trips and loaded conditions. I have never seen anything higher than 165* with outside air temp at 100* and a heavy load (trailer & tractor) about 13,500 pounds. It usually runs around 150* if the outside air temp is above 70* with colder temperatures 55* down I regularly see 125* trans case temperatures. The oputside air temp seems to have a much greater impact than speed/load.
