I know you are not supposed to go over 1250 deg. before turbo. My friends say it is ok for a little bit. I just put a #10 in my truck full forward, i have a plugged wastegate, k&n air, couple of turns on the gov. spring, and annorod adjusted, stock timing. It is a 97 4x4 3/4 ext. 5-spd. This is the problem when i am running hard through the gears it gets hot, mainly in 4th it will reach 1500 before it hits 3,000 rpm. Is it ok to get that hot just for a few seconds till i back off somewhere up in 5th gear if so how long should be ok? It will be hard to back off if I am next to a powerstroke
And how long and hot is ok when pulling a trailer up a hill "not many in ohio"
