How in the heck do you get rotors off of my ram>?
Front Axle Seals
1/4 Mile ETs?
Well, when i notices a bad brake shake, i figured i would change my rotors or turn them. But, now i have one promblem, how in the heck do i get my rotors off of my ram? I have a 2500 Dodge Cummins, Long bed, extended cab. Took the nut off of the axle, and 4 bolts behind the rotor and the rotor wouldn't even budge when i hit it with a hammer on the back side to get it off. Anyone have any help, i am stuck. Nick
Hello, I looked into this same topic before and was told to have them turned on the truck. My dealer charges 100 bucks. I like my dealer so far and I think for the problems I was told i would encounter I would be better off haveing them do it. Hope this helps!!!
Have'nt looked at mine yet, too new, but are you saying that the rotors will not come right off for turning? I would have thought they would break away from the hub for brake maintenance and such.
50% of the front hubs with the sealed unit bearings will come off of the axle stub after removing the center nut and the unit bearing nuts.
The other 50% WON'T.
You will use a long 4 leg puller mounted on 4 of the wheel studs and screw the center thread screw against the center of the axle stub.
Anti-seize compound is highly recommended on the inside of the bearing/axle collar upon reassembly.
Good luck.
Frank S.
Had the same problem with my 95 4x4. Broke a 3-jaw puller, trying to remove the hub/rotor assembly. DC uses an extremely lousey (from a maintenance standpoint) hub/rotor design, that allows the hub bearing, which is pressed into the rotor as an assembly, to become rust-welded to the steering knuckle. I had to resort to fabricating a megalith slide puller that mounted to all eight wheel studs and had a 15 pound weight sliding on an approx 3' pipe. Weighs about 40 pounds, but worked great. Wet everything with a good penetrating oil, like kroil or liquid wrench. It helps if you can get some longer 14mm -1. 5 bolts (in place of the 4 that secure the hub/rotor to the knuckle) and beat on them with a 32 oz hammer. As this is a fine metric thread, these bolts are hard to find though. It's also a good idea to zip tie the stub axles (at the u-joint flange)to the axle tongue so the stub axle won't come out when your hub/rotors do. Even with all this, and the use of a GOOD puller, you still may leave some of the bearing in the knuckle as the rotor comes off. This happened to one of mine. The bearings are are a Timken Unipack, not designed to come apart, and will need to be pressed together if they do separate. Some guys have done this without apparent problems, though I would not feel comfortable doing so. I replaced both of my hub rotors. Pricey at $310 each from DC. Again a very lousey design.
On the 2000, the design has changed in that the rotor does come off separately from the hub. There are lock rings on 4 of the 8 wheel studs, that once removed, the rotor will slide off.
Rotors still warp, and after turning will have to be replaced next pad change. That part still is lousy.
gave up
Well thanks for all the information, i got so freaking mad at those dam rotors i just gave up. Somethings are just better that way i guess. Nick
