how is this thing wastegated?
Tail pipe tip for enhanced exhaust CTD
Anyone have the black DiPricol fuel isolator mount?
my little 35 is taking a beating i am trying to limit boost i got a boost elbow from piers and checked to make sure the wastegate line was not pinched this had no effect on it. the wastegate is still disabled. i want to the wastgate to work so i can control boost with this little elbow.
with the new gsk's in i can make it hit 45lbs with 3/4 throttle.
i am babying it until i can get this wastegate to close at 35lbs
any ideas how this turbo might be wastegated? this is as stock hx35 i think.
is this the turbo you can put a spent . 22 shell in somewhere to block wastegate?
hook up some air pressure to the signal line and watch for movement at the wastegate arm...
is your elbow adjustable? sure it's not just turned all the way in?
If the diaphram is fine and you want just an elbow you can get one from the hardware store, it's a 1/8th pipe thread 90 degree barb for a 1/4" hose.
Jim
