How many bearings in a Dana 80 rear
Lift Pump Situation
A
brake booster run out
2 bearings on the pinion , 2 on the ring gear carrier , then there is the axles , not sure but 2 per wheel ??
should all be timkens ...
Two on the pinion, two on the carrier, two on each axle end. Total number is eight for a complete axle with hub assembly.
The bearing type is a tapered roller bearing.
The manufacturer of the bearing may be Timken, but more importantly, the standard bearing interchange number is on the outside of the bearing sleeve which is the same standard number for all manufacturers. Timken, BCA, Toyo, etc.
