how many fueling box's can you have
How do I change Brake Shoes on a 1 ton?
auto trans temp sensor
Ive seen some sigs that show people have an Edge with an Edge EZ. Can two fueling box's be used at one time. I know where the EZ plugs into. where does the Edge plug into?? If this is possible what combo works best with the EZ??
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
Tom. . If yours is an ETH you'll be waisting $$ as the ETH has computer signals that only let you use a small amount [maybe 25 HP additional] with the PE... the EZ is about all the pump will allow... BUTTTTT if yours is the ETC stack away and enjoy #ad
as it has no 'puter commands to stop the fun. .
OOOOOPS just read your sig. . your in luck. . buttt plan on seeing Bill K. if you go to far as the transmission will not hold the power. . they plug into each other at the Map and the PE also plugs into the pump wire with a pin type devise
Tom... Willyslover is right... from what I read on this board, anything more than the EZ will start you into transmission troubles. You might consider some gauges... I believe the ETC comes with a 9cm2 exhaust housing... heat could be a major problem with stacking boxes. One BOMB almost always leads to another!
I've seen ETCs with stock injectors, PE and EZ in the mid 300 hp range. You'd be doing good to get an ETH above 300 hp with the same configuration. Add larger injectors to an ETH with a PE and the PE becomes worth nothing. Dollar for dollar it's better to add injectors to the ETH instaed of a fueling box.
I've been running two boxes, the TST PowerMax2 and the BD Plug-N-Power with 275 injectors and the stock turbo. Highest ET I have seen is 1100. Original clutch won't hold but the Centerforce is still in with 45,000 miles.
