How many miles on Amsoil?
syn-blend oil
Mag-hytek Differential cover on 2500 Auto Dana 70
At 95K miles I changed to Amsoil. Presently I have 117K and the lab tells me no correction is necessary. However, I'm a bit nervous after going 22K miles without a complete oil change. The only new oil was the required filter change every 7500 miles. Please excuse my paranoia, but just how long can this stuff last? Any high miles out there?
[This message has been edited by Donley (edited 12-23-2000). ]
Are you using the bypass filter? If so, trust the lab.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
I do not have the by-pass. I run the 5-30 1 year, about 35,000, change my filters at 7500.
Never had a test come back saying anything but good to go. I figger a year is enough.
Gene
1997 Cummins Dodge 4x4 Bombed & Amsoiled. Amsoil Premiere Direct Jobber, Member of: NRA Business Alliance, GLTDR, WANTED: Wrecked Dodges.
www.awdist.com
I am using the Amsoil 5W30. As of now I am changing my filter at 5000 miles and then the oil/filter at 10000. I am sure I could go longer but I do not take any samples. I was going 10000 miles before I changed oil/filter
but I read on here where somebody was changing there filters at 5000 so that made sense to me. On my 95 & 98 I was changing oil/filter at 10000 and no problems. My son has a 99 with 70000+ and he has been changing oil/filter at 10000 but he is going to start doing what I am. Thats all.
2000 Dodge 4x4 Quad Cab SWB 5-SP
First I'll answer the question, then I'll ramble:
I went 12655 on my Delvac 1, with one filter change at 5721 miles. I'm planning on similar intervals with Amsoil HDD 5W-30, but only if Silicon stays reasonable after I start driving dirt roads again in the Spring.
Oil Analysis results on the Delvac 1:
Truck miles / Oil Miles / Si / Fe
16845 / 5721 / 10 / 34
23779 / 12655 / 15 / 71
I changed filter, added 1. 5 qts, removed
Psychotty and added foam pre-cleaner at about the time of that first sample. I do not have a bypass system, and as you can see both Si and Fe continued to increase but at a lower rate.
My first reactions to these sample results was considerable concern. Too much Si, way too much Fe. But all my other wear metals were low, so ??? The good news was that it looked like the foam pre-cleaner had reduced my Si intake and Fe wear rates, so maybe my "problem" was under control. Then I went back and searched for all past posts with actual oil sample results, and calculated for each one how much Si and how much Fe per 5000 miles. After making that adjustment, guess what? Newer trucks always have higher Si and Fe, older trucks have less.
All this confirms what others on this board have said: These trucks take a LONG time to break in. My rate of Si and Fe weren't going down because my Delvac was getting better as I put more miles on the oil or because of the foam pre-cleaner; they were going down because my truck was still wearing in at ~20,000 miles.
I changed to Amsoil, and I'll bet $100 my next analysis will show reduced Fe wear. Now, here's where it gets tricky. I'll also bet $100 that I could have stayed with Delvac, and my next analysis would still have showed lower Fe, because my truck is still breaking in! (I changed to synthetic at 11124, if anyone was wondering. )
All you folks who believe your wear went down when you changed from Brand X to Brand Y, or from 15W40 to 5W30 even within the same brand, please do an experiment for us: Change back to the previous oil for just 5000 miles, and tell us if your wear goes back up, or does it continue to go down because even at 60,000 or more your truck is still getting better with age?
I'm going to continue to do oil analysis for benefits like knowing if my air system develops a leak, but I think I will have to take the results with a grain of salt and not read too much into them. Heck, maybe I'll even take my own bet and switch back to Delvac at the next change just to see what happens. Your results may vary, this is JMO. #ad
2001 ETH, QC, LWB, 4WD, 3. 54, SPA Pyro & Boost, K&N RE-880 w/foam pre-cleaner, ARE Z-series Cab-high shell, Rear ARB locker, and all kinds of synthetic fluids...
HC,
Myself and a few others have concluded the same thing, small changes don't make any difference.
What we have decided to keep an eye on, are drastic changes from sample to sample.
PPM are pretty small, and can fluctuate from a number of different things.
Now that I have 2 years in sample taking, I have a good idea what my wear rate is. Now if something jumps, I know I need to start looking.
It may be something simple, like knocking dirt into the sample, or major, like a headgasket.
I think it is still more accurate than tasteing the dipstick!!LOL
Gene
Donley:
I have the Dual-Bypass on mine with 15-40 Amsoil. I have had 2 analyses done on mine with the results being every thing OK. The miles on the original Amsoil is 32,400. I change the filter at 7,000 and the by-pass at 24,000. If anything is going on inside the engine the test don't show it. I presently have 184,000 on the truck and am going to change oil at 200,000 any way. The K&N has been removed for a Mopar paper one. Didn't have time to clean the K$N.
Hope this helps a little
Preston
96 3500 Black 5 speed turbo diesel, SLT, with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , with other goodys on the way.
