My 4" BD brake is set at 20psi @ idle. It will go up to 40psi tops on a down hill with the engine revs at 2500. I have 60# springs throughout so my thinking is I should be able to adjust for a higher top pressure. Am I understanding this right? The 60# springs are good to 60psi or is that 60# of spring pressure.
I just want to adjust for max braking.
Larry
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
Larry
