Well I guess a erased that post, I ment to erase the "a little low part" I realized that there are just to many variables different between how my truck was set up with the EZ and yours is. With a stock exhaust with the dynomax and the WD filter that might be about right. What setting is your EZ on? With an analog gauge it is very tough to figure the peak pressure as the max spick happens so fast. The tell-tale on my SPA alway shows about a pound more then I have seen flash by.
Try adjusting the turnbuckle and see if it does anything. And always check your exhaust manafold bolts and intercooler hoses once in a while to make sure you are getting full air to the engine.
Ted
