how much for wheel bearings and seals??
injectors
diesel song
You can bet it wont be cheap
I think it is like 4hrs per side. (Someone with a Chilton Labor Guide can correct me) So, at even a conservative $50/hr, you are looking at $400 labor, plus probable "retail" of $40 a piece for bearings, and then shop fees, which are about 3-5% of the total labor charge.
Daniel
Find a warm place to do it and I might come a help. They are no sweat on a first genner. Where are you at midwest dually? I think the bearings are about $100, and the ujoints are pretty pricey $45 a piece, and seals about $12 for the good stuff. I think this about what i pay when I get neglectful. For some reason water crossings can kill them!
Michael
Midwest, I dug this up from when I did my front end...
Randys Rocks!
Called yesterday, still not parts, cancelled order with local dist and took JFitz's advice and called Randys Ring and Pinion (800-292-1031). Nice organization, very helpful, knowledgeable. Got my parts coming, should arrive monday.
For Reference, here is a list of the parts being replaced. First column is the exploded view reference number (Spicer Drawing), second column is Spicer part number, third is description:
32 620058 Upper kingpin seal
33 37305 Lower kingpin seal
34 41777 Lower Kingpin bearing seal
35 706150X Lower kingpin bearing and race
43 620132 Upper kingpin cap
44 37307 Upper kingpin cap gasket
45 37300 Kingpin spring
46 620180 Kingpin spring retainer
47 41886 Uppper kingpin bushing
48 37302 Upper Kingpin
57 620062 Inner spindle seal
58 37312 Spindle thrust washer/spacer
59 37311 Outer spindle seal
60 620063 Spindle bearing
63 48816 Hub seal (Inner wheel bearing seal)
64 706411X Inner wheel bearing + race
65 706074X Outer wheel bearing + race
Randys sells the kingpin parts in a kit, just like JFitz says, you get it all, including bolts. The spindle parts (57,58,59,60) are also in a kit. I did get the wheel bearing parts from local supplier (63,64,65). Price of all items, excluding wheel bearing stuff: $109. 56.
Now if I could just get that broken bolt out, I'm all set
Pat
If you want to read the entire thread, search for kingpin removal. Sorry, I couldn't figure out how to post the link:( :eek: I'll try and remember to look at the receipts tonight and get the rest of the pricing.
Pat
