... ... on a 430hp, C-12 Cat?
I suspect we may have fuel injector problem on one cylinder, but want to rule all of the other possibilities first. Truck has 2 fuel filters. First one is a water/fuel separator filter that is on the frame rail. Other, is the one on the engine itself. Both were replaced recently. It did help the engine run a bit smoother, and the boost came back up a little (as did some of the power), but still doesn't feel up to snuff. More in the 1000-1400 rpm range. Not noticeable so much empty or bobtail, but feel it going through town loaded and while upshifting.
What, if any, is the recommendation to replace the vibration dampener? Have ~413k on the truck. IIRC, Cummins suggests a new damper on the N-14/855 @ 380k, and John Deere recommends 5yr/5000hrs on most of their engines.
At first, it was bad enough to make whichever hand was on the steering wheel feel a bit numb before the new fuel filters. Not that bad anymore.
We do have an OEM fuel restriction gauge, but it has always been below 5" restriction, at least for the filter on the engine. No gauge for the water/separator filter. No pyro, either.
Any help would be appreciated.
