How much $$$ is an oil press sender?
SPA Gauges
Where do I get oil analysis kit from
Eric, I recall around $70 for an OEM sender plus $12 for a sender socket for the install. Cheaper aftermarket auto parts senders don't hold up, save your money by buying the OEM first.
Thanks Bill. Now I have to decide if it's worth the $70. 00+ to have the dealer do it.
I'm assuming it's covered by the 100K warranty.
Eric
Heck if it's free let them do it. Such a simple job. Disconnect wires, unscrew old one, screw in new one and connect wires. Got mine at NAPA and have over 200k on it.
If I can get it for a little less, I'll do it myself.
Now, if it was a liftpump that would be an entirely different story.
I think theyre a bit more.
Eric
Got mine for 64$ at my local Cummins shop. All you need to install is a 1 1/4 or 32 MM deep socket(a 6' extension helps). Takes 5 minutes.
Glenn
