Okay, so here's the deal, I blew a head gasket on Sunday, blew a bunch of coolant out of somewhere and then I had oil in it when I filled it back up. So I tore the head off, no cracks in the head, and I can still see the cross-hatches in the cylinders. (114,000 miles) Like the day before this happened, I noticed a little coolant weepage by the thermostat housing, didn't have time to check it out thoroughly, and the coolant level was fine. I thought it was from the housing, but now I wonder if it was coming from the head gasket.
So anyways, my question is, how bad can the head be warped with no ill effects. My manual says . 0004 per 2 inches, or . 012 overall. Using about an 18 inch precision straight edge and a feeler gauge, I can't get more than . 001 to . 002, but when I lay the straight edge on there from off the edge of the head, I can get . 003. You can tell the edges of the head are slightly warped up. (Or down if the head were on the engine. )
So my question is, what is the limit? What have you guys run with no ill effects? Should I just have the head surfaced?
Also, the exhaust valves look fine, but the intake valves are slightly beat in, you can see and feel the lip, so I guess I should have them ground.
Does anyone have the part number for the . 010 over head gasket?
Any help would be appreciated as I'm trying to get this thing back on the road.
