How much more torque with the 275s?
CA P7100 Timing vs. Plunger Lift
Turbo Classifications???
Rocket, should be about 100 ft. lbs (flywheel). As far as the stock TC and VB it should be fine but you will be at the limit. It's been recommended if you pull you might want to look at a minimum of a new VB.
IMHO
Devon
Rocket,
Here is a good comparison graph from Diesel Dynamics:
"By popular demand our customers have asked us to show a comparison between the Bosch 275hp RV injector and the Diesel Dynamics True Torque II injector series. This graph shows typical gains with the 275hp RV injectors and DD stages 1,2, and 3".
"This is a graph of a 99 Cummins Ram with Std Transmission.
The pink graph shows the truck with stock injectors as received.
The light blue graph shows the typical 30hp gain with the 275hp RV injectors.
The green graph shows the horse power improvement with our True Torque II Stage 1 injector. True Torque II Stage 1 injectors also carry the same part number as your stock injector.
The red graph is typical of our stage 2 True Torque II injector
The dark blue graph shows our very well documented True Torque II Stage 3 injector in action.
As you can see there is obviously no contest. True Torque injectors are carefully matched blue printed and assembled to yield outstanding and unequaled hp and mileage improvements. If you are only looking for a slight improvement in hp and do not want a carefully hand assembled injector for your Dodge Cummins we can supply the RV injector for only $300. 00 a set. "
Johnny,
When I was Looking at injectors I had many people tell me as well as read on some other threads that the DDIIs made more power and produced lower EGTs than the 275s. I just had my DDIIs put in today. Holy smokes(literaly) they do puff but I hit can 90 mph before the EGTs can even climb. I would definitly look into the Diesel Dynamic injectors before deciding on 275s.
Jeff
Thanks, but I already have them. I can't afford any trans mods right now. I hear ya though. Maybe when I'm done paying off this monster.
Johnny
