Low side pressures
RDusch is right on with the Low side temp thing. I still have my old 83 Chevy (cough) that I converted to 134 about 7 years ago. When I set that one up, I set the low side pressure at a point where it was just above freezing in the evaporator. That pressure will vary some with ambiant temp variations but if you set the low side pressure where he says, that may do it. If you happen to have the evaporator freeze up, just hook up to it and add a pound or two to the system to cure that. Remember, the temperature in the evaporator is controled by the low side pressure in the system. Your compound gauge set has a temperature crossover listed below the pressure on the dial so you can get an idea of what's going on in there when it's running. Rule of thumb is that the exit air temperature is usually around 20 degrees higher than the evaporator's actual temperature. Hang in there! These systems can be made to work.
Also, if you do a search back in the archives here, you'll find out there is a R-12 substitute available that is not harmfull to the ozone layer. I forget the name of the stuff but several of the ppl in this forum have used it with good results. Have a look and see if you can find out what it is.
Hope this has shead some light on the subject. See Ya! Racer
