Can't comment on the 2's, never had them. I did run with just the EZ for a while, then the EZ and step 3's, then the EZ, step 3's and a TST comp. , and finally the current set up is TST,EZ, BD step 5's. Here's what I have found...
With just the EZ, even on the most aggressive setting, all I could do to get a small puff of smoke, had to really get in it with low boost for a wisp of visible smoke.
Added the BD step 3's, no longer a problem creating a fair amount of black smoke, though most driving was smoke free. Step on it hard with low boost gave medium thick smoke 'till the turbo spooled up, after that clear running.
Added the TST box, believe it or not, not much of a change in smoke, the turbo spooled up quicker which surely helped matters.
Added the step 5's, can no longer do a smokeless start, especially on a hot, humid day ( my limited testing finds the humidity to play a larger role on the smoke issue than the heat alone). If I start in 1st gear, run the rpms up to 2800-3000 between shifts , very little smoke before spool up. On the other hand,
, if I nail it with low boost, you will fully believe that you have left the road and are now following a coal train.
Short story... we have a bunch of good ole boys from Delta Gulf working on a gas line in town. I worked an O. T. detail with these guys for one day, couldn't ask to meet nicer, down to earth folks. Most of these guys drive either PSD's or CTD's and love their trucks and diesel engines. The other day I stopped on my way into work at a local deli and saw to of the workers eyeballing the truck (read stack). I starting chatting with them and they asked if I had a problem filling the stack with exhaust from that little I-6. I gave them a
and said I'll show you when I leave, you decide. I left the deli in second gear ( which will smoke pretty good by itself with low boost), shifted to 3rd and then 4th by the time I hit 35, then put it to the floor
. I swung back around and found them both almost bent over in tears, said they never saw so much soot coming from a diesel, let alone a 24v'er. I gave them both a photo copy of the TDR mailer and bid my farewells.
Needless to say, I reproduced the same stunt again when I left
Bottom line is smoke ain't for everyone, I would stay away from the larger injectors and stick with a fueling box if smoke concerns you. This way you can control your output. As for me, I'm keeping the 5's, the felt HP/TQ increase with the injectors is huge, even with the ETH. Hopefully, I will find the time for another dyno sometime soon to prove my seat O' pants meter.
Scott W.
