Competition How much spray can B1/B2 compound take?
Competition Stock P-Pump CC's?
Competition SunCoast Dyno Results
Swayse
I've only hit them with a 100 shot so far. Any bigger than that, and I'll think I'll have to go to a second stage. I've got the shot coming in at about 35 to 40 psi, and it hits in 1st gear. It hits hard enough to spin the tires in 4wd. I come off the line just barely spinning, perfect, and it stops spinning, and then the shot hits and it spins a little bit again. All and all it worked perfect. I'm thinking I need to go down to a 75 shot at 35 psi, and another 75 to 100 at about 55 to 60 psi. I'm only running about 65 psi of total boost, and the waste gate does a good job of keeping it there. But, the more I spray, the harder the bottom turbo will spool. I'd like to hit an 11. 4 at 118 or so.
I found out that the ATS aurora 5000 don't like more than a 70 shot, it blew with a 140 shot. It didn't blow when the spray came on, it blew when I locked up the converter, broke the shaft. The nitrous blew out the fire when the turbo blew and killed the truck, so I got no garbage in the motor, just a little in the intercooler. :D
