Mine made around 20-22 PSIG stock. The generally accepted method to get more boost is to use a boost fooler (to keep the ECM from defueling and setting overboost codes) and a boost elbow on the turbocharger. With the Edge EZ (which has a built-in boost fooler) and accompanying boost elbow, I made about 30 PSIG with stock injectors. With the DD2's, peak boost is around 33-34 PSIG.
The additional boost really helps in dropping the high EGT's the HO is prone to run in stock configuration. When towing our 13,500 lb 5th wheel, I could hit 1300 degF pre-turbo EGT stock. With the EZ, BHAF (big honking air filter) and 4" exhaust, this dropped to 1100 degF with stock injectors. The additional fueling of the DD2 injectors has brought it back to 1225 degF, still well below stock levels and making 340-350 rear wheel BHP and 750-800 lb-ft of torque.
Rusty
Rusty
