How much will a Dana 70 take?
Delivery Problem - Suggestions?
X-Tended Warrenty
Does any have any idea how strong a Dana 70 is compared to the 80? How much muscle can I add without trouble while pulling 12,000lbs?
Larry, can not say much about the 80 as I run the Dana 70..... But the 70 is one stout unit. I pull 36,000lbs Everyday almost. After 300,000+ miles I had the rearend rebuilt. I work the piss out of this 92 but it keeps on going. HTH Mike
92 Std cab. LE. 215 P-pump reman cummins motor. 5-speed, 3. 54, 105 gal Aux tank in bed. Borgeson shaft, Banks Power pack. 12cm Hot end housing w/wastegate. 4" Exh, Pyro & boost guage, oil temp guage. E-brake. Galaxy DX99V, Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html
I suggest the Mag Hytec cover with its greater lube capacity and higher level in the diff to lube the outer bearings better. It also gives more room for lube to travel out there. I have seen more than one D70 with the outer axle bearings on the left side burned up. Also get a good lube for it, you might talk to Roy about it while you are talking to him for a cover.
