How often do you change your oil?
  • Every 3,000 miles
    Votes: 64 12.1%
  • Every 3,750 miles
    Votes: 23 4.4%
  • Every 4,000 miles
    Votes: 28 5.3%
  • Every 5,000 miles
    Votes: 173 32.8%
  • Every 6,000 miles
    Votes: 29 5.5%
  • Every 7,000 miles
    Votes: 18 3.4%
  • Every 7,500 miles
    Votes: 91 17.2%
  • Every 10000 miles
    Votes: 52 9.8%
  • Every 15,000 miles
    Votes: 29 5.5%
  • Other
    Votes: 21 4.0%
  • Total voters
    528
Another stupid injector question poll!
NV5600 Availability, Should we be Scared?
I dump the oil every 10k, though I change the Frantz filter every 2500miles, main filter at 5000. So by the time I hit 10000, I have replaced 1/3 of the original oil from topping off.
On all my other trucks I changed every 15K with Amsoil oil and bypass filters.
The 06 is a little new, but once the bypass gets installed I'll be doing the same thing with it. Its had synthetic in t since about 4K. One of these days I'll get around to installing the bypass filter . . . . . . :rolleyes:
I change the oil every 15K and the oil filter every 7500K. Been doing this since the truck had 10k. I have 90K on it now and the oil samples come back fine.
Jeff
Was 5k on Rotella before adding the Amsoil bypass, now I'm stretching everything to 10k (oil, main filter, bypass filter).
I was changing the fuel filter every 10k as well, but since I got the FASS, I am basing the change off pressure and so far, I have almost 40k on this filter with no drop in pressure. Probably change that filter every 10k.
steved
Was changing at 5k mark for a while, but since the frantz has been installed I will be changing at 15k with rotella dino juice. A new roll of tp at 2500 and a new full flow at 7500. Went 14k on amsoil before the frantz and had good results with just a full flow filter.
Every 5k with Delo 400. Just because it's easy to remember. I also do the axles, trans and x-fer case every 15k with Amsoil.
Every 15k in the '06 with Amsoil and Donaldson filters, every 5k with Rotella in the '03 with Fleetgaurd filters, every 10k on fuel filters. 50k intervals on diffs and t-cases with Amsoil. 30k interval on auto trannys with dino and approved Mopar additive.
Oil and a Stratopore filter at 5000 miles. Seven micron fuel filter at 10,000 miles. This is on a 2004. 5. The fuel schedule will change when I upgrade to a GDP kit with a Walbro pump and filter system.
GO ahead and Cringe! I have not changed my oil since the truck had 8,500 miles! It now has 62,000. I use the Amsoil 15W-40 HDD & Marine, by-pass filtration and a Donaldson "Full-Flow" filter along with oil analysis each 10K. I have changed both filters twice in that length of time, and the oil analysis is still showing the oil to be in great shape. Viscosity is still testing like a new oil, and soot/solids is 0. 20%wt.
Why dump it if it is still as good as new stuff?
WAyne
amsoilman
