On a 6. 7 because of the fuel that is going to get into the crankcase from normal emissions operation you need to follow the oil change light (preferred) or oil sample, not any time or mileage in the owners manual. Now let me clarify. The time and mileage in the owners manual is the maximum, assuming no light has come on yet, but chances are for most drivers this is not going to happen.
If the light comes on at 3,500 miles and you ignore it and drive it to 7,500 you will probably have around 10-12% fuel dilution in the oil, exactly what the manufacturer is trying to keep you from doing. So before you ignore the light, understand what you are doing and use sampling to verify the lubricant condition. Trying to be smarter than some engineer that is "just trying to be a money maker for Dodge", might just prove you right. They are going to make a LOT of money off you when YOU get to buy that engine!
And don't think you can outsmart them either, because the controller also keeps track of the oil change light, and it better match pretty close to your oil change records.
