I've been researching all night about my trucks "symptoms", and figured I'd try here. This may be a borderline 911 call, but I'm not sure how severe of a problem, or how soon until Ol' Gus leaves me stranded on the side of the road. So here goes:
Symptoms:
1. Had a real bad squeak coming from under the truck when coasting to a stop with transmission in gear or neutral. The squeak (high pitched squeel) was rpm related and slowed with speed.
2. Squeek went away after a couple of weeks (I couldn't find anything).
3. Then recently started hearing a "clunk/thunk" while disengaging the clutch, coming from under the truck in the driveline (transmission, clutch area). This is shifting from any gear at any speed, but does not occur at every shift.
4. Now, coming down a slight grade today, in 5th, I could let off the throttle then just as I reapplied pedal pressure, I would get the "clunk/thunk" again (not shifting).
I've done the research and can't narrow it down between the clutch, transmission, driveshaft (u joints), or other. I'm guessing a bearing (maybe pilot bearing) or something to that effect.
Is this something that can bust and leave me stranded? Where should I look first, and how do I test for it? I don't want to keep driving it and causing more damage in other components. I'd like to get it fixed asap.
Thanks for the help.
Symptoms:
